I'm using the Attribute table widget with the config "Synchronize with layer visibilities" checked. My layers are mostly "Map Image Layers". But I notice that when I open the attribute table, all tabs for all layers are visible even though just a few layers are visible. Turning on layers and then turning the off again will make the tabs disapear from the attribute table.
When using the add data widget, the new layers does not show upp in the attribute table, but after turningen them off and then on again they appear in the attribut table.
Is this by design? or a bug? or some configuration I got wrong?
I experince this both in WAB 2.16 in my Portal 10.8.1 and in ArcGIS Online.
