Alright,
I am on my way to the home base. Now, hopefully the last question I will have to ask for a while. I have all my scripts working for my Citizen Problem Reporter. I even have it updating in the reverse. Took some real innovative thinking but Workforce updates and Citizen Manager Reporter both update each other whenever there is a change.
Now, when I run my script manually the script takes about 45 seconds. When I set up the task scheduler it took 4 hours/ 2 hours to run even though I set one up to run every 20 minutes and the other to run every 5 minutes. Workforce assignment creator and service functions scripts respectively.
I googled a solution. I exported it and changed the priority to 4 and reimported the task. I am scared to change it below that. That didn't work. They are still running too long to run.
I have windows 10 64 GB RAM 64 Bit Operating system with 64 based processor
I tend to run a little on the high side for my memory because of ArcPro but that hasn't been a problem so far when I do it manually.
Any suggestions?
