We are in the processing in moving our geodatabases to a newer SQL Server (2016) instance. Our IT department wants to use a different port (53094) that we're currently using (1433).
While we could proceed that way, we realize that all of our legacy MXDs would need to have their data sources remapped. So not a good solution (enterprise wide, we probably have thousands of MXDs, although not all used).
We use an alias (GIS_xyz) to reference our database server & what we are trying to determine is if there's a way to essentially create an alias that also specifies the port.
I've been trying to see if I could use a Windows User or System DSN as means but have not gotten that to work yet although that seems like it should partially work. The problem I see with that, however, is that it seems the user/password are embedded there. So if I am able to create a User Data Source named "GIS_xyz" that points to the new instance/port, it will have a specific user name hard-coded in it. We use SQL Server Authentication with multiple accounts (one for data owner, data editor, data viewer, etc) and it does not seem like I can create multiple DSNs with the same name that have different account info in them. Ideally, I would want the credentials in our .sde files to pass through to the DSN.
Any tricks/tips on how to gracefully switch to a different port without having to repath all your legacy MXDs?
Thanks!
