Oriented Imagery Questions
77
203.8K
12
POST | Hello all. I'm trying to use the Publish Oriented Imagery Catalog tool from a freshly downloaded and installed Orient... by cdevault_pickett New Contributor III 0 4 | 0 | 4 | 154 | |
POST | When trying to publish an oriented imagery catalog I get a message stating - Error Please sign in to continue. I am s... by CharliePoate New Contributor II 1 5 | 1 | 5 | 346 | |
POST | Hello, We're using OIC Classic to launch a crowdsourcing project to label images collected by the Civil Air Patrol, s... by krpic New Contributor 0 1 | 0 | 1 | 189 | |
POST | Hello, I have a bunch of .jpg files that I need to add to OIC. I have added EXIF information to the images, which see... by Kejti New Contributor II 1 3 | 1 | 3 | 489 | |
POST | I'm getting the error "Unable to Fetch" using Local images and ArcGIS Pro Add-in. by HassanMahmoud_el07 New Contributor II 0 7 | 0 | 7 | 1026 | |
POST | I've downloaded both the Mapillary and Oriented Imagery Add-ins for ArcGIS Pro (I'm currently running Pro 3.1.3). Wh... by SarahRijneke Occasional Contributor 0 1 | 0 | 1 | 340 | |
POST | Hello,I'm using MDCS provided with Oriented Management Tools for ArcGIS Pro to create and manage Oriented Imagery Cat... by GiuseppeGentili New Contributor III 0 3 | 0 | 3 | 2648 | |
POST | We have created a frame table, in geographic the coordinate system, and everything works fine. Coverage looks great! ... by ngwoodhouse New Contributor 1 2 | 1 | 2 | 406 | |
POST | Another issue from the long list of issues that OIC has. Sometimes I wonder if this tool is just a test or a very bet... by bogdanpalade2 New Contributor III 0 5 | 0 | 5 | 663 | |
POST | Hi all,I am publishing an OIC from ArcGIS Pro 3.1.0 to Portal for ArcGIS using the last version of the management too... by bogdanpalade2 New Contributor III 0 1 | 0 | 1 | 287 | |
POST | I am trying to import images from a folder collected with a GoPro 360 camera. I create an OIC and then try importing ... by JamesGuilford New Contributor 0 1 | 0 | 1 | 542 | |
POST | What approach should I take to create a frustum, similar to the one generated by OIC for 3D, to visualize the coverag... by jauhari_mani Occasional Contributor 0 0 | 0 | 0 | 344 | |
POST | Even when setting my near distance to 0 I am still getting a 6 m space between my exposure point and my coverage poly... by DougBrowning MVP Esteemed Contributor 0 3 | 0 | 3 | 454 | |
POST | Hello. Im trying to add images to an OI Catalog using the command "Add Images to Oriented Imagery Catalog". Just a sm... by PatrikEriksson New Contributor 1 1 | 1 | 1 | 845 | |
POST | Could not extract coordinate info to add image:I am unable to import from an ImageList. I have configured a csv file ... by JeraldAllen New Contributor III 2 0 | 2 | 0 | 402 |
