Warning 003387 Input raster cell size error
185
03-23-2024 06:01 PM
Labels (2)
jesusangel
I downloaded sar images and processed them using arcgis, created a data set and trained the U-net neural network, but I have an error when using the "classify pixels using deep learning" tool as I get the following error:
Warning 003387 Input raster cell size 0.000105 is not within the cell size range [0.000109, 0.000110] the Deep Learning model has been trained for. Results may not be optimal. Consider setting another cell size in the environment, or using a different raster input, or using another Deep Learning model.
The sar image in which I want to do the classification has the same characteristics as the one with which I created the data set, I do not understand the error, how can I solve it? since if I run the classification it does not detect anything, it helps
