ArcGIS Pro Questions
452
141.5M
18.1K
NOTE: ArcGIS Pro ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Open | By default have the Full Extent button zoom to the full extent of operational layers and ignore the basemap's extent.... by Joshua-Young Occasional Contributor III 2 0 | 2 | 0 | |
Already Offered | Add field view to TOC right-click list. There are way too many steps to turn on a field in Pro. Please add the Field ... by MelanieWawryk Occasional Contributor III 0 2 | 0 | 2 | |
Open | THE PROBLEM: The Back Button Switches Catalog Pane's Tab, instead of stepping out of a specific Geoprocess to Geoproc... by Andrew_Lintz_DRGA New Contributor II 3 1 | 3 | 1 | |
Open | ArcGIS Pro 3.2.1In many Windows applications, such as File Explorer and browsers like Chrome, it's possible to click ... by Bud Notable Contributor 2 0 | 2 | 0 | |
Open | ArcGIS Pro 3.2.1When toolbar buttons are greyed out, they don't seem to have tooltips available when I hover the mous... by Bud Notable Contributor 2 1 | 2 | 1 | |
Open | After years of having a dual-monitor setup, I now primarily use GIS on a 13" laptop, as do many of my students. Eek! ... by wayfaringrob Frequent Contributor 4 1 | 4 | 1 | |
Open | When working in the fields view, for example, the fields options appear in a really strange location - between the vi... by wayfaringrob Frequent Contributor 3 2 | 3 | 2 | |
Open | I would like to see improvement in the load times for resources on network drives. My organization has excellent hard... by AmyRoust Occasional Contributor III 0 2 | 0 | 2 | |
Open | Several years into using Pro, I still find myself getting these two mixed up.Aside from both having the same briefcas... by wayfaringrob Frequent Contributor 2 0 | 2 | 0 | |
Open | In applications like:WindowsChromeFirefoxEdgeWindows ExploreriOSSafari...we're able to triple-click to select all tex... by Bud Notable Contributor 2 1 | 2 | 1 | |
Open | Right now, when dragging a layer to another view, you cannot scroll through the visible tabs with the mouse wheel -- ... by wayfaringrob Frequent Contributor 1 0 | 1 | 0 | |
Open | Most Windows applications will close their current tab or window with the Ctrl+W keystroke. The same is true of macOS... by wayfaringrob Frequent Contributor 3 0 | 3 | 0 | |
Closed | @KoryKramer Feel free to close this idea. Support is submitting bug reports for these issues. Edited: I removed the p... by Bud Notable Contributor 1 5 | 1 | 5 | |
Open | it is maybe straight forward but just a simple UI update but synchronizing thumbnails is necessary.In the catalog pan... by Stefan_Thorn Occasional Contributor II 5 0 | 5 | 0 | |
Open | To open the attribute table of a feature class, the right-click menu option is "Attribute Table": To open the attribu... by Bud Notable Contributor 0 1 | 0 | 1 |
Idea Submission Guidelines
User | Count |
41 | |
40 | |
18 | |
10 | |
10 |
