ArcGIS Navigator Blog
63
7.6K
POST | We'd like to use Navigator for a few of our staff to get to inspection sites. We'd like to add a display-only layer t... by Barry_Zickuhr New Contributor II 0 5 | 0 | 5 | 180 | |
POST | Just started working with Navigator this week, so I am pretty new to what the app can do. Is it possible to edit rout... by RossFindlayCOC New Contributor III 0 2 | 0 | 2 | 164 | |
POST | Navigator displays a white / blank screen when there is no GPS Fix, once the device has a GPS Fix, navigator maps are... by 6w-nick New Contributor II 0 6 | 0 | 6 | 224 | |
POST | Hello. I need to create a custom navigable map, and I'm not quite sure if I'm on the right path, perhaps, someone cou... by damirq New Contributor 0 0 | 0 | 0 | 179 | |
POST | I am having problems with ArcGIS Navigator when downloading AGOL mobile map packages (mmpk's) that are over ~3.4GB. F... by 6w-nick New Contributor II 0 10 | 0 | 10 | 508 | |
POST | I am trying to get the best way for the driver to cover all these line segments (in red) using ArcGIS Navigator. I cr... by AzwanTrekker11 New Contributor 0 2 | 0 | 2 | 334 | |
POST | Users are complaining they can't search on part of a name, can you customize search? by TL2 Occasional Contributor III 2 8 | 2 | 8 | 405 | |
POST | using the ArcGIS network Analyst, and having the network dataset, we have created a Geo Processing tool with arcpy an... by MohsenJanmohammadi New Contributor II 0 5 | 0 | 5 | 544 | |
POST | Hi everyone,Is there any way to add satellite basemap into Navigator ?I tried to publish it as mobile map backage wit... by NasserAlHinai New Contributor II 0 1 | 0 | 1 | 343 | |
POST | Is it possible to get a route between 2 features or drop pins rather than from your GPS location, like Google Maps? I... by Y_Chau Occasional Contributor 0 1 | 0 | 1 | 393 | |
POST | I created a mobile map package with a custom Network Dataset to be used in Navigator It has worked in the past, now I... by CoryAlden New Contributor II 0 12 | 0 | 12 | 989 | |
POST | I need to create a route with 600 stops. Can one route have 600 stops? by YukoYokozawa Occasional Contributor 0 3 | 0 | 3 | 422 | |
POST | When trying to access certain routes in the Navigator application I see a Failed to create route no tracker pop-up an... by Anonymous User Not applicable 0 5 | 0 | 5 | 756 | |
POST | Can ArcGIS Navigator be used with no stops? I have a client that would like to use this for snowplow driver navigatio... by markmorrison1 New Contributor II 0 1 | 0 | 1 | 374 | |
POST | I have successfully been able to see my pre-planned route made in AGOL in the ArcGIS Navigator App, however, I want t... by AmandaBeck Occasional Contributor 0 0 | 0 | 0 | 337 |
