ArcGIS Instant Apps Questions
83
2M
621
Open | I found out the other day that both these templates don't have the option to enable the legend on the map.It would re... by Ed_ MVP Regular Contributor 0 2 | 0 | 2 | |
Open | There are functionality issues with selecting a value from a drop down menu when editing data using an iOS in Instant... by TheaEvans New Contributor II 1 0 | 1 | 0 | |
Open | It would be nice if we had the choice to hide the toolbar if we only have one widget in the Sidebar Instant App. I'm ... by ChelseaRozek MVP Regular Contributor 1 3 | 1 | 3 | |
Open | I would appreciate it if in Atlas Instant App will be option to sort layers and maps, which I can add to map. For e... by AnnaHradecká New Contributor III 3 0 | 3 | 0 | |
Open | It would be great if there was increase the export/print options when configuring Export in the Sidebar Instant appPo... by RyanBohan Occasional Contributor III 3 2 | 3 | 2 | |
Open | Hi, I'm currently in the process of trying to pull together a 'site checker' which will enable the users to select a ... by James_Shreeve New Contributor III 0 4 | 0 | 4 | |
Open | In the Media Map instant app, the setting for "Enable hover pop-up" is currently located under About --> Location det... by PeterKnoop MVP Regular Contributor 0 0 | 0 | 0 | |
Open | Hi, Simple idea, which I believe can be implemented in Experience Builder Could it be possible to change the eye icon... by James_Shreeve New Contributor III 0 0 | 0 | 0 | |
Open | Unlike other areas of AGO, you can't filter by group when adding content to an instant app. Once you select My Groups... by wayfaringrob Frequent Contributor 1 0 | 1 | 0 | |
Open | Atlas is great Instant App template, but I have recommendations for Map Layer list:1) Show options (transparency, swi... by AnnaHradecká New Contributor III 4 0 | 4 | 0 | |
Open | Please add the ability to override layer visibility in Portfolio so that different layers from the same web map can b... by HaileyWright1 New Contributor III 1 0 | 1 | 0 | |
Open | Please add URL parameters options for Inset apps. It would be great if I could change the extent/center of this app, ... by Ed_ MVP Regular Contributor 6 0 | 6 | 0 | |
Open | When making an instant app webviewer, it would be nice to be able to turn off configurable pop-ups for image services... by LisaH152 New Contributor II 1 1 | 1 | 1 | |
Open | Here is an idea for this entire site:How about cleaning up and removing all old posts and solutions that no longer ap... by DeanChiang Occasional Contributor 1 0 | 1 | 0 | |
Open | I have many maps that require users to zoom in in order to conceptualize the data. I tried out the Inset Map Instant ... by JamesPoeschel Occasional Contributor 1 2 | 1 | 2 |
Idea Submission Guidelines
User | Count |
4 | |
1 | |
1 | |
1 | |
1 |
