Good explanation about Commercial ASP License?
6862
9
03-12-2017 08:03 AM
MichaelGinzburg
Occasional Contributor II
Hello,
ESRI License agreement require Commercial ASP license for providing commercial (e.g. ASP) access to ESRI software.
What does this license mean regarding ArcGIS Enterprise?
Is it just more expensive license with the same functionality (server & portal)?
Are there functionality limitations?
Unfortunately could not find a good explanation on the Web.
Thanks in advance!
Michael
by Anonymous User
Not applicable
Commercial application service provider (ASP) allows third-party access to Software, Data, Web Services, and Documentation. A commercial ASP means a Licensee who uses Software, Data, Web Services, or Documentation for a site or service and operates the site or the service for a profit or generates revenue by charging for access to the site or service.
MichaelGinzburg
Thanks Riccardo,
Is there some software packages limitations?
For example, does ArcGIS Enterprise Commercial ASP License include Portal?
Regards,
Michael
by Anonymous User
Not applicable
ASP does not include Portal. You would have to develop your own website and username authentication in order to do web mapping.
MichaelGinzburg
Is there any way to use WAB with the Commercial Server?
Thanks!
DerekLaw
Esri Esteemed Contributor
Hi Michael,
When you say "WAB", I believe you are referring to Web AppBuilder for ArcGIS; and the term "Commercial Server" means the GIS Server component of ArcGIS Enterprise.
Web AppBuilder is designed to work with web maps from a portal - this could be an ArcGIS Organization or a Portal for ArcGIS instance. You would connect and sign into a portal, then access one of its web maps to enable data content in a new web app. You can access web services from a GIS Server directly in Web AppBuilder using the Add Data widget.
Hope this helps,
MichaelGinzburg
Hello,
Does recent rebranding of Server and Portal as a single ArcGIS Enteprise product influence the ASP license?
Is there ArcGIS Enterprise ASP License?
Thanks!
DerekLaw
Hi Michael,
The software was simply re-branded from "ArcGIS for Server" to "ArcGIS Enterprise" at the 10.5 release. There was no change in its ASP licensing. The ASP license does NOT include the Portal for ArcGIS component.
Hope this helps,
TomBrowne
Hi Derek,
After buying the no expired ArcGIS Enterprise ASP License, is it mandatory to buy annual ASP Maintenance? Can we decide whether to buy the maintenance ourselves? Thank you very much.
DerekLaw
Hi Tom,
> After buying the no expired ArcGIS Enterprise ASP License ...
I think you meant to say "now" instead of "no" in the statement above. No, as far as I'm aware, it is not mandatory to purchase annual maintenance, but recommended so you can get updates and access to Esri Tech Support. As always, I suggest you discuss licensing details and options with your Esri account manager/local Distributor.
Hope this helps,
