I'm trying to use ArcGIS Earth to read a KMZ file but the outline of this county keeps disappearing under the other layers. The drawing order is correct, the outline is above the layers with the census tract info. Also the outline layer is in the same folder as the hash pattern that can be seen in the pictures but for some reason the outline disappears under the census tract layers when they're turned on. The hash pattern however is always visible. Any ideas why this would happen? Does it have to do with how the PHP is written?
Hello @TaelorM1,
Thanks for pointing out the issue. Currently. We could not reproduce it. Can you provide us with the data so that we can fix the issue quickly and with high quality?
Your feedback and suggestions are vital to us.
Thank you!
ZheZheng
For recording purposes, 4.25.2024 post from Anonymous User belongs to @ZheZheng.
Hello @TaelorM1,
Thank you for your support.
Our team is currently identifying and analyzing the issues, and addressing them as high priority.
I'll keep you updated as soon as we make some progress.
Thank you!
ZheZheng
