I think with a Data Expression this would be simple enough using a GroupBy statement. The only trouble is you'd need to manually adjust the expression for every year you wanted in the output. To get the entire thing to be dynamic and add columns for each year, it would be a bit more involved. But still possible!
Here's the easy way:
var fs = FeatureSetByPortalItem(
Portal('your portal url'),
'itemid of your service',
0, // layer index
['can', 'date'],
false
return GroupBy(
fs
'can',
{ name: '2023', expression: 'CASE WHEN EXTRACT YEAR FROM date = 2023 THEN 1 ELSE 0 END', statistic: 'SUM' },
{ name: '2024', expression: 'CASE WHEN EXTRACT YEAR FROM date = 2024 THEN 1 ELSE 0 END', statistic: 'SUM' }
- Josh Carlson
Kendall County GIS
