Webapp - problem with statistics (Max-Min)
1540
5
09-13-2016 04:13 AM
by Anonymous User
Not applicable
I have configured a webapp in AGOL and includes the Query widget: Query widget—Web AppBuilder for ArcGIS | ArcGIS.
I query an MapServer and the calculated Max-Min gives a incorrect result.
It works for some object - but not all.
A workaround would be  to let the user disable some of the results in the widget.
RobertScheitlin__GISP
Can you provide more details? And an example of the mis-calculation?
by Anonymous User
Not applicable
Look at the attached file.
Sveaskog,
   Thanks for the example. I will tag the Dev Team on this. junshan_liu-esristaff‌ as you see in the attached document the statistics max should be 20 but it is reporting 18.
JunshanLiu
It’s a known bug and it has been fixed in this online release. Could you go to online to have a check?
by Anonymous User
Not applicable
It looks good!
