I am upgrading a Qt application from Qt 5.15 and Esri Maps SDK 100.15 to Qt 6.4 and Esri SDK 200.1, but now I am having trouble deploying it in Windows. When I double-click the exe in the 'deployment' folder to run it, there is a quick flicker and then nothing. The app closes immediately. I have also tried building and deploying a simple Esri Qt Quick QML application, built from one of the templates that comes with the SDK, and I get the same error.
I added plugin debugging ( qputenv("QT_DEBUG_PLUGINS", "1")) and some logging to this test application to troubleshoot, and it shows an error when trying to load the ArcGISRuntimePlugin.dll (it is looking for it in the sdk install directory, not in the application directory):
qt.core.library: "C:/Program Files/ArcGIS SDKs/Qt200.1.0/sdk/windows/x64/qml/Esri/ArcGISRuntime/ArcGISRuntimePlugin.dll" cannot load: Cannot load library C:\Program Files\ArcGIS SDKs\Qt200.1.0\sdk\windows\x64\qml\Esri\ArcGISRuntime\ArcGISRuntimePlugin.dll: The specified module could not be found.
qt.core.plugin.loader: QLibraryPrivate::loadPlugin failed on "C:/Program Files/ArcGIS SDKs/Qt200.1.0/sdk/windows/x64/qml/Esri/ArcGISRuntime/ArcGISRuntimePlugin.dll" : "Cannot load library C:\\Program Files\\ArcGIS SDKs\\Qt200.1.0\\sdk\\windows\\x64\\qml\\Esri\\ArcGISRuntime\\ArcGISRuntimePlugin.dll: The specified module could not be found."
qt.core.plugin.loader: Found metadata in lib C:/TEMP/troubleshooting/testMap_200_1_build_Qt652/qml/Esri/ArcGISRuntime/ArcGISRuntimePlugin.dll
Here are the steps that I am following (I also tried running this process in Qt 6.2.9, which is what these steps are from):
C:\Qt\Qt6.2.9\6.2.9\msvc2019_64\bin\windeployqt.exe --core --opengl --sensors --positioning --widgets --quick --network --multimedia --qmldir C:\TEMP\troubleshooting\testMap_200_1\qml --release C:\TEMP\troubleshooting\testMap_200_1_deploy_Qt62 > C:\TEMP\troubleshooting\testMap_200_1_deploy_Qt62\packlog.txt
When I run a similar process with Qt 5.15 and Esri SDK 100.15, it works fine.
I have tried several things to troubleshoot, including:
Any suggestions on what I am missing in this process?
Thanks.
Hi @KCLewelling. Thanks for reaching out to us.
Looking over your QT_DEBUG_PLUGINS output, I think that's pointing to the culprit. It looks like your app is attempting to load our QML API plugin (ArcGISRuntimePlugin.dll) from two different locations:
If you reconcile these, I think it may work for you. Our other dlls to watch out for are:
One other thing I spotted, which may be fine is that these dlls are likely OpenSSL 3, which is only supported out-of-the-box with Qt starting with Qt 6.5.
If you're using an older Qt version, you'll need the older SSL dlls. Usual caveats apply with encryption, so this is just a build configuration thing I noticed.
https://www.qt.io/blog/moving-to-openssl-3-in-binary-builds-starting-from-qt-6.5-beta-2
Let us know if that works for you.
James,
Thank you for your reply and help, particularly your mention of other dlls to watch for and the OpenSSL version. I was missing runtimecore.dll. I added that and replaced the OpenSSL dlls with the 1.1.1 versions, but I also needed to explicitly add websockets to my windeployqt.exe call. Then my deployed application ran. (In case it helps others, I found that Qt6WebSockets.dll was needed by using the Dependency Walker tool to check the different dependencies on the ArcGISRuntimePlugin.dll and EsriCommonQt.dll modules.)
To summarize, here are the changes I made to get this working:
Thanks again for your prompt reply and help!
Kelley
That's great to hear, @KCLewelling. I forgot about the new websocket dependency we'd added in the 200.x timeframe. Glad you got that one figured out.
