Arcpy - Select by location - iterate through gdb feature class and export to new fc
1092
04-05-2020 08:06 PM
BrianMcNamara2
Hi, I am trying to use arcpy to run a select by location and export the resulting selection (intersect) as a new feature class. I have set my workspace to the gdb containing the featureclasses I want to select by, and the features I want to select are a tile index feature class called 'tile_index'. The code will run but doesn't have any output. Any help would be great.
Thanks!
# Import arcpy and set path to data
import arcpy
arcpy.env.workspace = r"C:\folder\Data.gdb\"
# Get the list of the featureclasses to process
fc_tables = arcpy.ListFeatureClasses()
for fc in fc_tables:
   arcpy.SelectLayerByLocation_management('fc', 'intersect', 'tile_index')
   arcpy.CopyFeatures_management(fc_tables, r"C:\Data.gdb\%Name%_selection")‍‍‍‍‍‍‍‍‍‍‍‍
JohannesBierer
Don't know if I'm up to date but I think you have to use make feature layer infront of your select by location. Out of the help files:
import arcpy
arcpy.env.workspace = "c:/data/mexico.gdb"
# Make a layer and select cities which overlap the chihuahua polygon
arcpy.MakeFeatureLayer_management('cities', 'cities_lyr')
arcpy.SelectLayerByLocation_management('cities_lyr', 'intersect', 'chihuahua')
you should use:
arcpy.env.workspace = r"C:\folder\Data.gdb" and not
r"C:\Data.gdb\%Name%_selection" will not work in python code,
you will need to create a unique name for your output file.
Ian-Horn
I'm trying to do something similar, but instead of writing selected features to a layer, I want to deleted the selected features.
arcpy.env.workspace = r'K:/3DBasemaps/3DBasemaps/scratch_raw_points.gdb'
# list feature classes in the workspace
treeFeatureClasses = arcpy.ListFeatureClasses("", 'Point')
print(treeFeatureClasses)
for fc in treeFeatureClasses:
    buildingPts = r'K:/3DBasemaps/3DBasemaps/scratch.gdb/' + fc
    print(buildingPts)
    arcpy.management.SelectLayerByLocation(fc,'ARE_IDENTICAL_TO', buildingPts)
    print(fc + " County points were selected againts " + buildingPts + " points")
    arcpy.management.DeleteFeatures(fc)
    print(buildingPts + fc + "points deleted from " + fc)
But instead of deleting the selected features, it deletes all the features.
