How to: Alter text elements in multiple MXDs simultaneously using a Python script
302
11-07-2024 09:26 AM
JaredPilbeam2
MVP Regular Contributor
https://support.esri.com/en-us/knowledge-base/how-to-alter-text-elements-in-multiple-mxds-simultaneo...
Is there an updated version of this for Pro? When I use the script with Pro-related updates there are no errors in the tool, but no changes are made. I'm currently debugging and the couple things I'm questioning whether they're actually doing their job are the counter and replace().
import arcpy
import os
#workspace folder
arcpy.env.workspace = ws = arcpy.GetParameterAsText(0)
Old_Text = arcpy.GetParameterAsText(1)
oldList = Old_Text.split(', ') #set the comma as separator for multiple inputs
New_Text = arcpy.GetParameterAsText(2)
newList = New_Text.split(', ')
f = arcpy.ListFiles("*.aprx")
for aprxname in f:
    aprx_path = os.path.join(ws, aprxname)
    aprx = arcpy.mp.ArcGISProject(aprx_path)
    for lyt in aprx.listLayouts():
        for elm in lyt.listElements('TEXT_ELEMENT'):
            counter = 0
            for text in oldList:
                if text in elm.text:
                    elm.text.replace(text,newList[counter])
                    arcpy.AddMessage(f'{aprxname} | updated to: {elm.text}')
                    counter = counter + 1
                else:
    aprx.save()
TonyAlmeida
replace
elm.text.replace(text, newList[counter])
with
elm.text = elm.text.replace(text, newList[counter])
TonyAlmeida
replace
with
JaredPilbeam2
Thought you had something there. I changed that at some point while debugging and forgot to put it back the way it was. Didn't make a difference.
TonyAlmeida
Maybe try,
            counter = 0
                counter += 1
JaredPilbeam2
@TonyAlmeida After implementing your suggestion, I did some further debugging and found the problem. These two parameters require a space after the separator when imputing multiple values, and I wasn't doing that.
So, if you have a space in the split() function then you need to put it after the parameter value too. Also, make sure your old text matches your existing layout text element or else it won't be found.
Working in Pro 3.3.2
import arcpy
import os
#workspace folder
oldList = Old_Text.split(', ') #split into a list, use comma and space as separator
for aprxname in f:
            counter = 0
                    elm.text = elm.text.replace(text,newList[counter])
                else:
    aprx.save()
