How do I export a file geodatabase table to ArcGIS Online?
557
5
04-19-2024 09:32 AM
GeoMapIt
Hi! I've been stuck for days on this. ChatGPT was not able to help me. This sounds like a simple thing to do. Or, at least it should be.
I'm trying to publish a file geodatabase table to ArcGIS Online using python (ArcGIS Pro IDE). That's it.
Tags (5)
BlakeTerhune
MVP Regular Contributor
GeoMapIt
Thank you for your reply. No, I need help using python api to publish the table. Preferably someone to send a simple code snippet that does this.
BlakeTerhune
Ah, yes, sorry about that. The FeatureSharingDraft class has a code sample for publishing a layer and a table.
FeatureSharingDraft—ArcGIS Pro | Documentation
GeoMapIt
No worries! That looks promising. I'll give that a test later today. Thanks!
Sean_Works
I had some success with scripts derived from this blog post last year.  Publish and overwrite web layers in ModelBuilder (esri.com)
