Hello Guys,
Hope you all are well!
I have the web map application built using Experience Builder, Now I need to use the print tool to print a map.
Now the print Tool will Generate JSON, This JSON I need to use ArcGIS Pro(Customize Geoprocessing Tool) to Export the PDF.
ArcGIS Pro is the only way to use the Pre-Prepared Templates while I have more than 100 for different Zones, Sizes, Layout, and map details like logos and others.
I have created that GeoProcessing tool and run it on ArcGIS Pro, Whatever JSON has been sent will print the map with the proper template.
The Issue is once I have Published that service from ArcGIS Pro 3.2 on the ArcGIS Server 10.8 I have The Error below:
ExecuteError: Missing or invalid layout template file.
Failed to execute (Print Map Script).
Failed to execute (Print Map Script).</Msg>
Are there any compatibility issues Reading the JSON of ArcGIS online map or Experience Builder map once using ArcGIS Server 10.8 while it works fine on ArcGIS Pro?
Note: I have downgraded ArcGIS Pro to 2.4 but the result was the same !!!
is arcpy.server.ExportWebMap() on ArcGIS Server 10.8 accepting syntax of the JSON as a map from Experience builder or ArcGIS online Map print tool???
