Hello, I'd like to create a python toolbox for ArcPro that imports all of its tools from scripts in separate folders and I want these tools placed in toolsets. I may even put toolsets within toolsets. This way I can manage the python code more easily and avoid having all of it in one python script.
It appears that when a tool is imported as a script from another directory, the tool's self.category field is not honored and the tool is placed at the toolbox root. Any ideas on how to implement this? Did I do something incorrectly or will I need to request help/fix from ESRI?
This is the desired outcome when viewd in ArcGIS Pro. This setup does not import the script files but contains all tools within one python file.Figure 1. Desired outcome.
This screenshot shows what happens when the tools are imported. The self.category settings appear to be ignored.Figure 2. Actual outcome.
Here is the code to reproduce the issue as seen in Figure 2. You will need to setup the folder structure as needed (see screenshots above).
import arcpy
import os
import sys
myScripts = os.path.join(os.path.dirname(__file__), "scripts","Import")
sys.path.append(myScripts)
from scripts.Import import First
myScripts = os.path.join(os.path.dirname(__file__), "scripts","Export")
from scripts.Export import Second
from scripts.Export import Third
class Toolbox(object):
def __init__(self):
self.label = u'Example_Toolbox'
self.alias = ''
self.tools = [First, Second, Third]
class FirstTool(object):
def __init__(self):
self.label = u'First Tool'
self.description = u''
self.canRunInBackground = False
self.category = "Import"
def getParameterInfo(self):
return
def execute(self, parameters, messages):
pass
class SecondTool(object):
def __init__(self):
self.label = u'Second Tool'
self.category = "Export"
return
pass
class ThirdTool(object):
def __init__(self):
self.label = u'Third Tool'
return
pass
This post was helpful in setting toolsets (self.category) https://community.esri.com/t5/python-questions/python-toolbox-toolset/m-p/636796/thread-id/49579
This post was helpful in importing scripts from other folders https://pro.arcgis.com/en/pro-app/latest/help/analysis/geoprocessing/share-analysis/packaging-python...
