I am trying to convert a dbf to a csv but come by this error when I hit certain characters (in this case á I think). I know there are many more.. Is there a way to force this to convert to utf-8? Is this the way to handle this? Any help is greatly appreciated!
import arcpy, os, csv masterTable = r"M:\Spelling_Project\Master_Table\FeaturesTable.dbf" CSVFile = r"M:\Spelling_Project\Master_Table\FeaturesTable.csv" fields = arcpy.ListFields(masterTable) fieldNames = [field.name for field in fields] with open(CSVFile,'w') as f: dw = csv.DictWriter(f,fieldNames) dw.writeheader() with arcpy.da.SearchCursor(masterTable,fieldNames) as cursor: for row in cursor: dw.writerow(dict(zip(fieldNames,row))) print row print "converted " + masterTable + " to a CSV file!" del row, cursor
*EDIT*
For anyone who will find this helpful, this is what I used to solve this.
import arcpy, os, csv, codecs def Utf8EncodeArray( oldArray ): newArray = [] for element in oldArray: if isinstance(element, unicode): newArray.append(element.encode("utf-8")) else: newArray.append(element) return newArray masterTable = r"M:\Spelling_Project\Master_Table\FeaturesTable.dbf" CSVFile = r"M:\Spelling_Project\Master_Table\FeaturesTable.csv" fields = arcpy.ListFields(masterTable) fieldNames = [field.name for field in fields] with open(CSVFile, 'w') as f: dw = csv.DictWriter(f,fieldNames) dw.writeheader() with arcpy.da.SearchCursor(masterTable,fieldNames) as cursor: for row in cursor: dw.writerow(dict(zip(fieldNames,Utf8EncodeArray(row)))) print "converted " + masterTable + " to a CSV file!" del row, cursor
Message was edited by: Chris Brannin
Working with utf-8 encoding in Python source - Stack Overflow
apparently, you have to include
# coding: utf-8
at the top of your script...see documentation for 10.3 as well
Python migration for ArcGIS Pro—ArcPy Get Started | ArcGIS for Professionals
# coding: utf-8
a = u'á trés bonne...those pesky characters'
print a
yields
or if coding is not visible but the code is
# coding: utf-8
a = u'\xe1'
print a
output
>>> á
