I'm currently using geopandas to iterate through individual features in ArcGIS Pro and rotate them. It would be great if a method was added to arcpy where features could be rotated easily by specifying an angle, and a pivot point as a coordinate pair/tuple/point features. Something like:
arcpy.edit.Rotate(in_features, angle, origin, radians)
Example:
import arcpy
arcpy.env.workspace = "C:/data"
arcpy.MakeFeatureLayer_management("platforms.shp", "platforms_lyr", whereclause="WTG_ID = 'AB01'")
arcpy.edit.Rotate("platforms_lyr", 30, (123456.1, 5465646.10), radians=False)
# Else, use list comp and search cursors to grab the angles and coordinates of each row in the attributes.
With cursors, the angle and origin coordinates could be derived from a field in the in_features or hard coded etc.
