Len Query in File Geodatabase
1973
6
08-19-2016 02:24 PM
AbdullahAnter
Occasional Contributor III
I can do len query easily in Personal geodatabase. But when I  try to do this query in File geodatabase , appear error. Queries ex:
Len ([field]) = 13      (personal geodatabase)
Len ("Field") = 13     (file geodatabase)
How Can I do this query in File geodatabase?
DarrenWiens2
MVP Honored Contributor
Where are you trying to run this query?
AbdullahAnter
Select by attribute using Arc Map 10.1
DanPatterson_Retired
or try the python parser but len would be lowercase and for file geodatabases, double-quotes or no quotes should work.  When building the expression, it is also best not to type anything, but select elements from the dialog to get the correct spacing and syntax... see Darren's link for more details.
DarrenWiens2
... of course, Select By Attribute has no Python parser...
oh crap... can't wait until vb is gone and they standardize their syntax... coming soon though
Specifying a query in Python—ArcPy Coming to a theatre near you| ArcGIS PRO
