UN Subnetwork Summary Fields
688
12-20-2018 12:34 PM
MarkCederholm
Several summaries are defined for the system and pressure tiers in UPDM, but they're not being calculated when I update the subnetworks.  I applied the UN patch to no effect.  Is there something I'm missing?
PaulLeBlanc1
Are the subnetLine features being generated with the summary fields as Null?
MarkCederholm
No they're coming out as 0.
MarkCederholm
I've submitted a tech support request case #02239285.
MarkCederholm
Taking a closer look at the subnetwork properties, I realized that the out-of-the-box valve and meter counts in UPDM use invalid asset types.  After updating the asset types to correct values, I'm getting the counts.
For MAOP, I switched the function from MIN to MAX, because services do not have MAOP populated.  I found the aggregated lines property to be confusing, but I think I have it straight now.  If I exclude services from aggregated lines, they don't contribute to the subnet line geometry, but they still contribute to summary attributes.  However, it looks as though I can set a filter in the summary to exclude them, though I'll have to create an asset group network attribute; I'll do some more playing around with that.
