Exam Comparison: GIS Fundamentals Foundation 2024 and ArcGIS Pro Foundation 2101
Not sure which exam is best for you? When determining which exam level and version is best for you, open the Exam Information Guide from the Exam Details Page and compare the exam information. If you’d like to personal your approach, read this blog: A Personalized Approach to Exam Selection.
- Experience: The GIS Fundamentals exam is designed for candidates with 150 hours of GIS coursework or 3-6 months of GIS workplace experience and the ArcGIS Pro exams validate the skills and experience with Esri software at between 0-2 years’ experience.
- Exam Duration: The GIS Fundamentals Foundation exam allows for 1 hour, and 30 minutes and the ArcGIS Pro Foundation exam duration is 1 hour, and 30 minutes.
- Exam Blueprints are significantly different (table below) and shown on each Exam Information Guide: GIS Fundamentals Foundation and ArcGIS Pro Foundation.
GIS Fundamentals Foundation 2024 | ArcGIS Pro Foundation 2101 |
Data Discovery - 35% | ArcGIS Fundamentals - 18% |
Identify steps to add data | Identify the use and purpose of the ArcGIS components |
Identify data types | Recall procedural concepts necessary to work with ArcGIS Pro and ArcGIS Online |
Identify coordinate systems | Apply concepts required to select appropriate ArcGIS applications for a given workflow or use-case |
Define fundamental GIS concepts | |
Discover content in ArcGIS Online | |
Describe how to use map navigation tools | |
Processing and Analysis - 22% | Data Management - 34% |
Describe how to use attribute tables | Identify how to access data properties |
Recall how to perform analysis | Describe the purpose of item details, item descriptions, and metadata |
Recall how to edit local data in ArcGIS Pro | Identify the correct procedures necessary to create a file geodatabase and a feature class |
| Identify supported ArcGIS data formats |
| Recognize the different data management techniques in ArcGIS Pro and ArcGIS Online |
| Determine the appropriate method for managing tabular data |
| Identify basic editing workflows that are necessary to create or modify features |
| Recognize the purpose and characteristics of geographic and projected coordinate systems |
Mapping and Visualization - 25% | Mapping & Visualization - 23% |
Identify steps to change Basemaps | Recall how to apply and modify symbology |
Recognize how to represent and style data | Determine the appropriate method to modify layer properties |
Identify steps to generate labels | Identify the steps necessary to label features |
Identify layer properties in ArcGIS Pro and ArcGIS Online | Identify the use and effects of scale on a map |
| Identify the steps necessary for adding data |
| Demonstrate an understanding of how to configure map properties |
Managing and Sharing Content - 18% | Sharing Data - 11% |
Describe how to validate a map for sharing content from ArcGIS Pro | Recall how to discover content from ArcGIS Online |
Organize content in ArcGIS Online | Determine the appropriate method to share content from ArcGIS Pro and ArcGIS Online |
Identify elements of ArcGIS Online | |
| Performing Analysis - 14% |
| Determine the appropriate workflow using proximity and overlay tools |
| Determine the correct workflow to select features interactively, using attributes or by location |
| Recall methods to find geographic locations |
Best to you on your Certification Journey!
