New Technical Paper: Considerations for configuring antivirus software for ArcGIS Enterprise hosts
4716
17
12-09-2020 09:03 AM
RandallWilliams
Esri Software Security and Privacy has recently released a new technical paper:
This document augments the existing kB: FAQ: Which ArcGIS Enterprise directories should be excluded for security or antivirus software? And is a valuable resource for teams installing, configuring, and administering ArcGIS Enterprise
Hosted in the customer only section of the ArcGIS Trust Center documents repository, this paper dives deep into:
  • Defining Risk Factors that influence virus scanning decisions
  • Differentiating between Anti-Virus tools and methods
  • Describing workflows where virus scanning activities should be relaxed
  • Identifying files, directories, and processes to exclude from active scans
17 Comments
DrewDowling
Occasional Contributor III
@RandallWilliams Is there a link to this document? I'm not seeing it and I searched the Trust center for the paper name and nothing is showing up.
NicholasEverdell
New Contributor II
BaileyBellavance
New Contributor III
Neither of these links work to access these articles, and I can't find it in the knowledge base. Can you please re-share these?
DrewDowling
@BaileyBellavanceThe document seems to have been moved to the "Customer Documents" section.
Try this link. I think you need to be logged in with an AGOL account.
https://trust.arcgis.com/en/customer-documents/ArcGIS_Enterprise_AV_Guidance.pdf
chriscothran1
None of these links appear to work now, and I don't see a document listing antivirus software exclusions for ESRI Enterprise solutions.
RandallWilliams
Link changed w/ version 3.1:
https://trust.arcgis.com/en/customer-documents/ArcGIS_Vulnerability_Scanning_Guidance_v31.pdf
Check out the other resources in the customer exclusive area of the ArcGIS Trust Center. You may also find the WAF guide helpful.
chriscothran1
@RandallWilliams Sir,  I don't see anything in that pdf listing exclusions for antivirus software.  Your original post in 2020 references a document and a KB that addressed what should be ignored by antivirus software.  Those documents seem to have been removed, and searches within ESRI's documentation have not produced relevant findings for me.  Thanks for your time.
Respectfully, Chris
RandallWilliams
OOPS, I'm forever tranposing the vuln scan guidnce and the AV guidance and the link is indeed broken.
I'll work with our doc team to get this fixed.
Leighton
@RandallWilliams Any update on this? I have urls that used to contain this info, they no longer work: https://support.esri.com/en-us/knowledge-base/000015732 and https://support.esri.com/en/technical-article/000015732. Not sure if that helps your work with the doc team?
RandallWilliams
There is an updated version in the customer exclusive documents repository in the ArcGIS Trust Center.
JeffClough
New Contributor II
Hi @RandallWilliams , I'm not able to locate this updated document after logging into the trust center and performing a search.  Can you please post a direct link?
And, of course I found the document just after posting the above.  Please disregard.
RandallWilliams
StephenKaranja
Thanks @RandallWilliams for the link.
chriscothran1
This link no longer works.  Does ESRI have a new list for Anti-virus exclusions?
Respectfully,
Chris
George_Thompson
Esri Frequent Contributor
@chriscothran1 the link works, but you must sign into the site first. Look in the upper right hand corner.
chriscothran1
Good morning George,
I've tried the link multiple times and it redirects me to Secure Documents | ArcGIS Trust Center | Documentation
which is the customer library.  I can go to any of the other pdf docs in that library.  It looks the file is no longer in the trust center.
Chris
RandallWilliams
Link works for me. If you're taken to the customer exclusive docs, this is the one you want.
