The certificate popup window warnings are a real-time suck for me in dev environments that don't have proper certificates when calling arcpy.CreateGeocodeSDDraft. Can a parameter be added to the arcpy server calls to suppress the warning? This problem makes arcpy useless in some situations.
print "Create sddraft" analyze_message = arcpy.CreateGeocodeSDDraft(loc_path=loc_path, out_sddraft=out_sddraft, service_name=service_name, server_type=server_type, connection_file_path=connection_file_path, copy_data_to_server=copy_data_to_server, supported_operations=supported_operations, folder_name=folder_name)
