Looking to fill hollow roads
632
08-23-2021 08:39 PM
Labels (3)
MeganBuckland
Hello everyone,
I recently created a network dataset to measure access to some points along a park's perimiter from houses within 200m. The only part of the data which is working in this analysis are the parts where the roads are directly connected to the parks. I have noticed that the roads are displayed as separate lines not solid lines. Unless the road is directly attached to the park, the network is limited to the line surrounding the house. I have attached an image to show what I am talking about.
I am hoping to make the roads solid/thick lines so that the network can travel across any road in any direction. I will not be able to do this manually using the edit  tool because there are over 10,000 lines...
I will give other information needed to help solve this problem in comments where needed. Thank you very much
