I want to install ArcGIS Enterprise 11 (Geodatabase, AGS, DS, Web Adaptor) on Rocky Linux.
Is that possible ? If so, are there any considerations I should be aware of ?
It does not look like it is a fully supported O/S: https://enterprise.arcgis.com/en/system-requirements/latest/linux/arcgis-enterprise-overall-system-r...
I have had clients install on unsupported version of Linux (i.e., Amazon Linux) and most of the functionality work, but they encountered something at the O/S level that Esri was not able to support and had to move to a supported O/S version.
I would say that your safest bet for support and success would be to use one of the supported versioned listed above in the documentation, based on my experience.
ArcGIS Enterprise 11.1 is the first Release supporting Rocky Linux 8 (Update 6+)
ArcGIS Enterprise 11.1 system requirements—ArcGIS Enterprise | Documentation for ArcGIS Enterprise
