I am trying to connect to a PostgreSQL database that has a few schemas, including public. In Pro we can only see the public schema.
Using the same credentials in PGadmin, I can see all the schemas and all the tables and views in each one.
Something else missing?
I wonder if there is an issue with the version of PostgreSQL you have. With Pro 3.2.x, the minimum supported version at v13.x is 12 (https://enterprise.arcgis.com/en/system-requirements/latest/windows/database-requirements-postgresql...). That could cause an issue.
I would update PostgreSQL to 13.12 (or newer) and then retest.
What version of Pro and PostgreSQL are you using?
Does the user have "superuser" assigned?
What are the permissions of the user in question: https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/manage-postgresql/privileges-postgre...
Pro 3.2.2
PostGreSQL 13.4
Its a read only account, we have admin too, but the use case only needs to view the data and not edit (Data Viewer role) with the same account and same credentials, I can see all the schemas
I am a little unclear about that list, I see
as a minimum requirement?
but it's true that we haven't updated in a while.
Here are the min. versions for Pro 3.2.x:
Each major version of PostgreSQL (12, 13, 14, 15, etc..) are different from each other and have minor "updates" (.x) for each major version.
Herer is the link to the latest supported versions for windows: https://www.enterprisedb.com/downloads/postgres-postgresql-downloads
Hope that helps.
How to Upgrade the PostgreSQL and PostGIS version for the Enterprise Geodatabase on Windows
How to Upgrade the PostgreSQL and PostGIS version for the Enterprise Geodatabase on Linux
How to Move the PostgreSQL Enterprise Geodatabase with pg_dump and pg_restore
PostgreSQL Geodatabase Guide Books and Database Template scripts.
Mapping and Charting Solutions (MCS) Enterprise Da... - Esri Community
use the Production Mapping guidebook for PostgreSQL, the best practices can be used by any industry.
ok thanks!
thanks!
curiously, I only see the public schema when i connect using ArcGIS (stand alone) catalog 10.8.2 as well.
