Currently ArcGIS Pro allows us to view which domains are being used in a Geodatabase (which is great). It would be further useful to report which domain codes are being used so that we can remove any code entries that are no longer in use. In the example below it may be useful to indicate that I am not using "de las" at all so I can remove that code from the domain and "to" 432 times so I can push that to the top of my domain so it appears first on the pick list
