You can search for posts and documents at several community levels. When you type a search term, the system automatically searches at the current level of the page you are on. For example, if you're on the community front page or using search in the top navigation bar, the system searches the entire community.
If you're looking at a page, board, or blog page, the system searches that board, documents, or blog.
To search the community, enter your search keywords in the search field and click Search or hit enter.
When the page of search results displays, browse the search results in the same manner you would a message board.
In addition to search results in the first post of a topic, you can quickly view the replies that also contain your search term.
You can see loads of information about each result, including when the topic started, the number of replies, the number of views, and the kudos count for the topic.
On the search results page, the default results tab is for Posts, but you can also select results tabs for Members and Places.
To apply filters, select from the options available to narrow by:
- Place
- Labels
- Author
- Date
- Status (Solved or Kudoed)
- Type of Post
- Contains (Images, Videos, Attachments)
Most search filters work together to narrow the possible results. For example, you can search for accepted solutions in the last month, and found in a specific place or board.
Active filters appear at the top of the results list. To turn off a filter, click the X to the right of the filter.
The Advanced link on the search results page is where you can Subscribe to RSS feed for the Search you created.
Advanced users will also have the ability to export search results. Once you have the results filtered to your specifications, look for the Advanced link select, Export Search Results to CSV. You will receive a private message upon request and then another once the CSV is compiled with a link to the file.
