Missing "BACK" button on Main Stage
2632
10-02-2015 02:27 PM
KateNewell
Is anyone else having a problem with Main Stage Actions in their map journal?
I created a map journal and have several Main Stage Actions in my side panel that brings up a web map. However, the usual "BACK" button that shows up at the top of the Main Stage is not showing up to get the user back to the original image/map.
GregoryL_Azou
Regular Contributor II
Sorry about your issue and thanks for sharing the link to your application privately with me.
I have been able to reproduce the issue and will try to fix it for our next release around mid November.
The issue appears because your Main Stage Actions is configuring the map popup.
If you configure the popup back to default, the ‘BACK button’ will be present as expected.
You can follow the issue being resolve through GitHub Main Stage Actions that configure the map popup don't have the back button · Issue #44 · Esri/map-jo...
In the meantime, I cannot think about a workaround.
You have to choose between dropping the popup configuration or not having the BACK button.
GregoryL_Azou
