Does ArcObjects works with ArcGIS 10.9 (and above)?
763
04-06-2022 03:50 AM
Tech_Mahindra_GISSingapore
Since ArcMap/ArcGIS Engine does not exist anymore with version 10.9 (and above), does ArcObjects work with ArcGIS 10.9?
Hi LeonS, thank you for the response.
According to ArcObjects SDK 10.9.1 system requirementsArcGIS Server is required to develop with ArcObjects SDK for Java Windows.
I managed to try this out in our environment, found to be successful.
LeonS
Occasional Contributor III
If you are looking to extend the functionality of ArcGIS Pro, similar to how you might extend ArcMap with ArcObjects, then you will want to look into the ArcGIS Pro SDK.
I believe the Mobile APIs for the ArcGIS Runtime would be the current functional equivalent of  an ArcEngine app built with ArcObjects
Link to relevant documentation:  https://developers.arcgis.com/documentation/
