cut polygons model
724
01-07-2021 02:27 PM
MahmoudHegazy
New Contributor III
i have boundaries which are red polygons , and that red polygon covered the building, i want idea to split
that red polygon in the edge of building that covered by red polygon automatically without crossed the out of build's edges
is there any ideas please
by Anonymous User
Not applicable
Hi Mahmound,
If you just intend to change the geometry, you can use the use edit tool to create a new line across the polygon.
Constructing polygons from the shapes of other features—ArcMap | Documentation (arcgis.com)
Is this what you were after?
MahmoudHegazy
New Contributor III
firstly thanks for your replaying
the tool that you notified it is not work for what i want and make gaps and clip each build according to the red polygon like that
i want tool split by percentages each red polygon split to polygon and on the build's edge and without gaps
like that
