Hi all,
I interested in seeing if anyone has run into this issue yet.
I am using ArcGIS Arcade in my popups in WAB 2.6 dev editon. When I use the Search widget to search for a particular feature, the Arcade expression is not visible in my popup in the found feature (I have the 'Show pop-up for the found feature or location' option checked in the Search widget config). However, I can click on the same feature again and then the Arcade expression appears. Has anyone else experienced this and if so, how did you get around it?
Thanks in advance,
Craig
