Using the WebApp Builder, I've incorporated the 'Near Me' widget to search for intersecting layers within a user defined buffer distance when either a location is entered in the search bar, or a pin is placed on the map.
I have two geocoders - The ArcGIS World Geocoder and the BNG locator.
Using either a pin or searching for a place name using the world geocoder works as expected and a buffer is drawn on the map, which is automatically zoomed to.
However, when I enter a grid reference (from the british national grid system) although the search returns intersecting layers it does not draw a buffer on the map. The search source settings for both geocoders are the same.
Any suggestions?
Many thanks
Katie
