Near Me Widget Attribute Display
302
07-20-2018 02:44 PM
GaryChristensen
New Contributor III
I'm using 10.6 Enterprise with hosted feature layers. In Web App builder the "Near Me" widget seems to have a bug with the resulting attributes it shows after running a search.  The app is configured to use a name field "text"  as the Display Field (Search Source Settings tab).  However, when running the app the widget displays the value of another field which happens to be the one used as the title in the attribute pop-up window.  The pop-up has to be enabled in order for this widget to run. Has anyone else experienced the same?
