Bookmark Widget will not load bookmarks from map in Web AppBuilder
255
11-09-2022 10:18 AM
bcgeogirl1
Hello. I have a web application which I have built but seem to be unable to add the bookmarks from the map it is based on. Everytime I add the widget and go to configure it i just get the loading symbol (the three verticle lines that alternate in height). None of the options are available to click in this loading mode and if you push ok it just gives you the option to add bookmarks (which does not work when you click on it), but does not show the map book marks. I only want the map bookmarks to show as the option to add bookmarks is not relevant for this appliation. Any idea why it is not working?
