I would love to see a widget in WAB or Experience builder that allows the user to achieve the same functionality used in the ArcGIS Pro Select by Attribute tool. It would be great to couple this with exporting the selection to different file types, zooming to selection, gathering statistics, viewing in an attribute table, etc. There is a custom widget hosted here:Select by Attributes Widget v1.1 07/20/2018; however, it causes some issues when other widgets are present in the map. It would be great if esri would make this a core widget!
