Stand-alone table in flex viewer
1894
7
09-26-2014 01:17 PM
JustinFultz
New Contributor III
Hello,
I need to be able to display a stand-alone table in flex viewer with all records. I would like it to behave like the attribut table widget where you just click a tab and the table displays. It also needs to refresh on a specific interval.
I have a current workaround that ties each record to a point that isn't visible(since it doesn't really relate to that point) and I am able to display the data that way. The problem is the loss of data as they zoom away from the points in the map. Also, with serveral hundred records on some tables, my services are being taxed pretty hard trying to redraw all those points for numerous clients when the refresh happens.
I would appreciate any suggestions. I have attempted to use Robert's enhanced search widget for tables, but I want all records selected by default, and haven't found a way to do that with his widget. Also, I'm not sure about a refresh on his widget.
The current production site is at https://pricecontourmap.spp.org/pricecontourmap/ . The current table is only around 20 records, but we need to add another with close to 800.
Thanks in advance for any suggestions!!!
Justin Fultz
RobertScheitlin__GISP
Sure, my site is doing it thru a URL Query. Look at the Enhanced Search Widget URL Search Configuration.pdf
Venkata_RaoTammineni
check somehow it helps you.
AttributeTable—ArcGIS API for Flex | ArcGIS for Developers
Thanks and Regards,
Venkat
Justin,
   There is just nothing out there that I am aware of that meets you workflow needs. You can have all the records selected in my eSearch if you use a Query of "1=1" but I do not have an auto refresh feature.
JustinFultz
New Contributor III
I could potentially make eSearch work if I could have the Query preload, similar to how it does on your example site for the widget. How can i force the 1=1 upon opening the widget?
Justin
JustinFultz
New Contributor III
That was one of my posts from a long time ago. It doesn't resolve the issue of needing it to work on stand-alone tables. Attribute table only works on layers.
Justin
JustinFultz
New Contributor III
Thanks Robert!
