Syntax for email address field input mask?
7172
03-29-2018 07:20 AM
BrentKinal1
Occasional Contributor III
I feel like in a past post I saw some syntax for using an input mask for an email address field, If I wasn't dreaming this and one exists please share the syntax.
Thanks!
Brent
JamesTedrick
Esri Esteemed Contributor
Hi Brent,
Input masks don't work with arbitrary length text portions, as you would expect from parts of an e-mail address.  As  documented, you can use a regex function to validate an email address:
regex(., '^(([^<>()\[\]\\.,;:\s@"]+(\.[^<>()\[\]\\.,;:\s@"]+)*)|(".+"))@((\[[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}])|(([a-zA-Z\-0-9]+\.)+[a-zA-Z]{2,}))$')
JamesTedrick
Hi Brent,
Survey123Jedi
New Contributor II
@JamesTedrick
I'm getting this text populating 3.14 Survey123 Connect.
I haven't used the email body::esri:inputMask in a while, what am I doing wrong?
IgorAtamanchuk
New Contributor III
The regex needs to be inputed into the "constraint" column in your XLSForm. Also, it seems like the preview won't show the validation, but it works well when the form in published. Hope this helps
