Survey123 URL Callback Fails with action=edit
539
03-31-2022 08:31 AM
Skyler
New Contributor III
I am running into an issue where callbacks in Survey123 links do not work when using action=edit.
For example, say I have a survey with itemID a62hh5926b1c429eb9f13ab2683c0a16. The following URL works to open a new instance of the survey in the field app and automatically return to Field Maps once the survey is submitted, cancelled, or saved as a draft.
https://survey123.arcgis.app?itemID=a62hh5926b1c429eb9f13ab2683c0a16&callback=https%3A%2F%2Ffieldmaps.arcgis.app
However, if I include action=edit and the filter parameter in the URL in order to open an existing record for editing, as shown below, then the callback fails—nothing happens when the survey is submitted, edited, or saved.
https://survey123.arcgis.app?itemID=a62hh5926b1c429eb9f13ab2683c0a16&action=edit&filter=globalid:aa79348f-ebc5-433a-b61e-653cf0ec49f6&callback=https%3A%2F%2Ffieldmaps.arcgis.app
I'm running version 3.14.242 of the field app. I have tried other variations on the parameters, and switching to the arcgis-survey123:// URL scheme, all with the same results.
ZacharySutherby
Hello @Skyler
Thank you for passing this along, we have BUG-000147973 logged for this behavior. Please feel free to reach out to Esri Technical Support and they will be able to attach you to the defect to track it's status.
Thank you,
Zach
