Am I missing something or is this a defect?
- Create a survey with "select_one_from file" questions, no CSVs in media folder as plan is to use linked content
- Publish survey
- Link the surveys in Survey123 Connect
- Download the surveys onto the Survey123 field app
At this stage of the workflow we would like to launch the survey from Field Maps. However the external select questions do not populate when the form loads.
Go to 'Collect' a new survey; a pop-up appears to indicate the CSVs are downloading. The questions then work fine.
Why does Survey123 not download the CSVs with the survey? I assume it will also not re-download the CSV files unless the user goes to 'collect'?
