Is it possible to use wildcards in if calculations? I want to return a true value if part of a string matches a piece of text, e.g. if(${speciesname} = 'Eucalyptus*', 1, 0). Is this possible?
Cheers,
James.
Please take a look at the regex function, which is described in detail at Formulas—Survey123 for ArcGIS | ArcGIS (bottom of 'Constraints' section) - you should get what you want with regex(${speciesname}, 'Eucalyptus')
Thanks James. That did the trick. I did look into using regex initially but couldn't figure out how to use it for my purposes from the documentation. The two examples provided are very complex and so I found it difficult to decipher how it worked. Perhaps a couple of simpler examples in the documentation would assist newbies to its use like me?
Cheers,
James.
