I have a Survey published to ArcGIS Online, created in Survey123 Connect 3.18.124. There are a few questions on the survey that are of type "select_one" that are using the search function in the appearance column to get its values from a hosted feature layer in AGO. That part works fine. On the web survey, if I click inside the drop-down field I immediately see the available choices. I can then click on one to select it. If I then want to change that selection and click on the drop-down field again, there is no list of choices that appears. I have to delete the text I entered first, and only then does the list of choices appear.
What I see when I first click in the drop-down field:
What I see after I choose a value and then want to change it:
Clicking the drop-down arrow itself does not make a difference.
So this is a frustrating issue for users that first selected a value and then want to select something else. They have to delete what they chose first before the list is displayed again.
This is what I have in the appearance column in Connect:
Any ideas on this?
