Linking GIS Enterprise with Power Automate
293
08-10-2022 12:55 PM
JoshOsowiecki
New Contributor II
We just got Power Automate and the use with AGOL is quite straight forward. However, I am running into an issue when I try and link my Enterprise account with Power Automate via an Application on Enterprise and a custom connector on Power Automate. Esri, has an amazing article explaining the process, however, once I get to the last step It seems as though the connection fails. I run into an issue on step 7, after I log into my Enterprise the operations on the Power automate window do not run, I am not even sure the log in completes.
Any help on this would be greatly appreciated, we are very eager to start integrating Power Automate into our surveys!
abureaux
MVP Regular Contributor
I put together a guide for setting up Power Automate and Enterprise. Hopefully this helps.
https://community.esri.com/t5/arcgis-survey123-questions/guide-to-generate-feature-reports-in-power/...
