Thanks, James. The barcode check logic is VERY simple. When the barcode is parsed, the only thing displayed on the form is a sequence number that is printed on all the supplies that the user is supposed to verify before distributing the supplies. If that number is incorrect, the survey user wanted the value that is displayed on the screen to be bold red or highlighted in some fashion. I know there are things like <font color="red"><b>[insert text here]<b></font> that can be used in the label column to change the style but I don't see information how to change the font, color, etc of input either calculated to display or input from the user that is displayed, But thinking about that, it makes more sense to display the CORRECT sequence number that is parsed from the barcode in bold because that's the number the user should be searching for on the supplies. I did that as a note and that works fine.
Are you saying that information either entered by the survey user or calculated to display on the form CAN be styled with different fonts, colors, etc? Where do I find information about that?
