Sorry it has been awhile but just after posting this I lost my entire HD due to a IT "patch".
Due to this I can no longer show you what I was seeing.
Luckily I had just published the surveys the day before. I was able to retrieve the surveys using the download option. Props to you guys that the new 2.7 does a much better job of downloading ALL the form info needed. In the past metadata, or media, or something would go missing (going back to 2015 when I started with Survey123).
But this points out even more how important it is to allow the path to the Surveys to change!
Our IT only backs up My Documents on the C drive so I lost everything in Survey123 (minus some older backups). I just do not understand putting it buried in a part of the users drive that almost no one ever backs up (and an area that many VMs bar the user from even seeing). Very bad spot where it is now in my opinion. I have got into the habit of backing them up manually but really I should not have to.
Really needs to be a network drive. Many IT depts are locking out the C drive completely now. In fact the last big Survey123 project I had was close to getting shut down simply because no C drive on our VMs.
If Survey123 is ever going to transition from small projects to enterprise scale this whole storage/share/production/dev/test file juggling needs to get worked out.
Please take this as constructive feedback.
thanks
