How To Change the Year Appearance of a Date Field to a Dropdown Year Picker
161
03-22-2024 09:07 AM
jantolihao
Hello, everyone!
I have a date field with a year appearance. Please see screenshot below. My concern is that I cannot "conveniently" select a year using this appearance. For instance, I want to select year 1960, I need to tap the + button multiple times before I can select 1960.
Is there a way to change its appearance to a dropdown menu or any "convenient" appearance for picking a year? By the way, for the Date Constructed field, the requirement is that: 1.) the field should be a date field, and 2.) the user will just pick a year. Thank you in advance for any hints/ideas.
abureaux
MVP Regular Contributor
There are no additional formats for this. You tell it "year" and the app/OS do the rest.
I find the "year" option frustrating for this reason, and typically just use "date" since you can scroll through that easier. You can extract just year from a full date if need be.
jantolihao
Thank you for this info, @abureaux. It seems like there are no other options.
