Fill out 1 survey, autofill and create multiple features
229
02-26-2024 08:13 AM
KellyTaylor
New Contributor III
hey all,
I work for a utility company and I'm building a survey where the user enters data about a leak and a work order to repair the leak. "Leaks" being the primary layer, and "Work_Orders" being a repeat. What I'm trying to do is have the user fill in a single work order (WO) while automatically creating 2 WOs. The first WO has a wo_type of either "service_leak" or "main_leak". I'd like the second WO to autofill all the same values except the wo_type would now be "recheck"
My instinct is to use indexed-repeat() but I may be misunderstanding how to use it. In the calculation column for the "wo_type" field I've put indexed-repeat(${wo_type}, ${Work_Orders}, 1). It comes back with a cycle dependency error.
Is there another way to achieve this?
Thanks in advance!
Tags (1)
KellyTaylor
New Contributor III
if anyone stumbles upon this and is struggling to do the same thing, I finally found a solution here.
Here's my javascript function:
function getValue(position, repeat, field) {
	if (position == 2){
		return repeat[0][field]
 and here's what I put in the calculation column in the xlsform:
pulldata("@javascript", "functions.js", "getValue", position(..), ${Work_Orders}, 'premise' )
with Work_Orders being the name of the repeat, and premise being the name of the field I'm copying over.
I had to put this in a null field called 'premise_null' and then set the 'premise' calculation to ${premise_null} in order to avoid yet another cycle dependency error 🤔
It's probably not ideal if you have a lot of fields to carry over because it'd need to run the .js for each field. If this was an issue for me, I'd write a js function that would return all the necessary fields in an array, store that in a null field in the xlsform, and then access each item in the array using calculations.
Good luck to anyone trying to do this! It took me forever to finally find a solution. It would be lovely if indexed-repeat could refer to earlier entries of the same field without a cycle dependency error.
KellyTaylor
New Contributor III
	if (position == 2){
