counting in a repeating section
273
12-21-2023 05:55 AM
Samuel_Colmenarez
Hello, I hope you are well.
We wanted to know if there is a way, that within a repeating section the count value is always fixed, that is, that in a question of the integer type with spinner appearance the number of the previous record is maintained and that the value is not added or subtracted unless the operator modifies it.
For operability reasons, ideally the field should be within the repeating section in question.
Thanks very much for any help.
Regards
ZacharySutherby
Hello @Samuel_Colmenarez
Unfortunately this is not possible at this time. Questions cannot refer to themselves in a calculation as it may cause an endless calculation loop and cause app instability.
Thank you,
Zach
